Oil & Fuel B7800 Hydraulic oil change
   / B7800 Hydraulic oil change #1
MarkyP
I purchased a Kubota B7800 from Bob Wolf @ Woodbury tractor 7 years ago at 40 hours 6 years ago I had Bob do the service. Now don't mad but I now have 70 hours on the tractor. When I had the service done I purchased all the fluids and filters I would need to do it my self.
I would like to state I am by no means a shade tree mechanic but the fluids I feel I can take care of with out a hitch LOL. I did the oil the other day using Rotella no big deal.
Now for some reason I can not find my owners manuel. I have everyone for all the attachments but here's where I am lost. If you are sitting on the machine near your right foot when using reverse is a yellow dip stick, this is a little low. I wanted to know If I wanted to add some fluid I so this under the seat is a Yellow capped plug. I have 2 5gal buckets of Kubota Superior UDT
hydraulic trans fluid? Is this where this fuid is added.
Should I change this fluid now or wait til I have 80 hours on the machine?
Mark
   / B7800 Hydraulic oil change #2
If you changed the tranny fluid @ 40 hrs. there is no need to change it now. If you did not you should change it. I have attached some manual pages for you. The yellow plug under the seat is where you put in the tranny fluid.
  • IMG.pdf
  • IMG_0001.pdf
   / B7800 Hydraulic oil change #3
FWIW - Six years is long time. Most manufacturers have both calendar and hour time recommendations. If you live in very dry conditions or park in a temperature controlled garage perhaps you can get by.
Personally if I had the stuff sitting there I would go for the change
Where did you get that book. If you could post a link I would order one up today. Thanks again and I am going to change the fluids. Wish me luck.
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
MILLER SYNCROWAVE 351 TIG WELDER (A52472)
MILLER SYNCROWAVE...
44509 (A51692)
44509 (A51692)
