jdgreg
I'm not familar with the 'Bota, but I had similar problem with front chains on my JD 4210. I simply flipped the tires around, they stayed on the same side, just turn them around. This put the tire tread going in the wrong direction, but with the chains on that doesnt matter. It does make the front stance a little wider, but that seems to add stability. I've done this for several winters with no ill effects, and I have a FEL snow blade on mine. Hope this helps some. Good luck to you guys and gals in this round of storms.
