B7800 Front Axle Rebuild
   / B7800 Front Axle Rebuild #11
Thanks for the info guys. I have a copy of the workshop manual but its a little different when it talks about setting it up. It has a setting the backlash section with a level type dial gage but from what I’m used to with the truck differentials we just painted the ring gear to get the correct pattern. Could I do the same? Or is it completely different? I want to make sure I do this right so I do not shell out the diff again as soon as I run 4x4 again. Has anyone rebuilt the front axle before?
Another thing to consider when you rebuild the axle....consider changing to regular 80/90 weight gear oil, instead of UDT/Super UDT. I don't know what the B7800 manual calls for, but most Kubotas seem to come with Super UDT from the factory. I blew a couple of gears on my b2910 a few years ago, and switched to 80/90 lube when I rebuilt it....no further troubles...knock wood.
   / B7800 Front Axle Rebuild #12
Manual calls for either super udt or 80-90
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
JOHN DEERE HAY CUTTER (A58214)
JOHN DEERE HAY...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
2019 DODGE RAM 3500 (A58214)
2019 DODGE RAM...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
