B7800 cruise control option
   / B7800 cruise control option #1
72chevy4x4
John Deere 3038e
I noticed another B model, maybe the B3030, which had some sort of cruise control lever (saw this in the owners manual). The B7800 I have has a pushbutton 'cruise', which may become tiresome in mowing conditions where we're mowing long straight stretches, turn then mow the other direction. Would be easier if the cruise didn't have to be reset each time. guess I'm looking for a 'resume' option similar to autos-I know...its a tractor-but it would make mowing a bit easier.
   / B7800 cruise control option #2
I have never operated a 3030 (mowing) so I cannot compare it to the 7800. But the 7800 cruise works well for me, get up to speed, set. Repeat.
The thing is, I really doubt if I am in the same speed for another round, since the ground is different. So a resume, (to exact speed), would not be useful.
-Mike Z.
   / B7800 cruise control option #3
The cruise control is a manual unit on both tractors, in order to have a resume, you would have to add electronics which would = $$$$.
   / B7800 cruise control option #4
Isn't the cruise on a 3030 and 2630 just a stiff hand lever much like a small garden tractor? It works in conjunction with the foot pedal I think.
   / B7800 cruise control option #5
Taiser is right about that
   / B7800 cruise control option #6
I have cruise control on my B2710.
I have tried it while mowing and do not like it at all. I guess it has value for some folks in certain conditions but I have to adjust my speed too often for it to be of any value to me - so far.
By using the hydrostat pedals, I become one with the machine - nothing perverse of course.
   / B7800 cruise control option #7
The B3030 cruise is a lever that pushes the hydro pedal and holds it where ever you stop. It takes some effort to push the cruise lever because it is moving the hydro pedal. You can hold the the hydro pedal at the speed you want to go and then push the cruise down until you feel resistance. The cruise lever will now move easily until it hits the hydro pedal. I assume that your B7800 button just locks the pedal at the position you are holding it. I guess, in theory, you could remember the location you had moved the lever to on a B3030 and move it back to that same position after you turned around. I don't think you are missing much by having the button instead of the lever.
An automobile cruise control is a closed system. A computer monitors the speed of the vehicle and adjusts the throttle to hold the speed steady. The tractor is an open system in that you are just setting a speed by locking the hydro pedal, therefore, the transmission ratio. If a large load is placed on the engine, the tractor will slow down and nothing in the system will correct for that. To truly implement a resume you would need a automobile type of cruise control which would mean adding a speed sensor, some type of servo to move the hydro pedal, and a computer to control the thing. Of course this would not work real well because you run the motor at PTO speed for the mower's sake and you control the speed of the tractor with the hydro pedal. If the mower puts a strain on the engine (tall grass, kid's toys, whatever), the tractor would slow down. The cruise control would push the hydro pedal to go faster (similar to shifting into a higher gear), which would put more strain on the motor, maybe eventually to the point of stalling it.
What you want is something that would just remember the last location you locked the hydro pedal at. Kinda like a block of wood just the right thickness to slip under the hydro pedal so that when you push it all the way down till the block stops it you are at mowing speed. If you had such a device, you could turn around, push the pedal untill it stops, and then hit the lock button. It doesn't sound too hard to fabricate something that would do that. You would have to rig up and adjustable pedal stop. I am thinking of something cam shaped that you could control with a lawn mower throttle cable assembly.
CASE 610 Sprayer System 2000 Gallons (A55218)
CASE 610 Sprayer...
2024 ATLAS CORPO PACF44 PORTABLE DEWATERING PUMP (A52705)
2024 ATLAS CORPO...
2017 Ford F-250 Knapheide Enclosed Service Truck (A55788)
2017 Ford F-250...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
Pickup Instructions (A47477)
Pickup...
2014 Ford Explorer SUV (A55758)
2014 Ford Explorer...
