B7800 blowing #2 10a fuse help
   / B7800 blowing #2 10a fuse help #1
bigboyga
Augusta, GA
Kubota L4600
I have multiple threads on this and spent an hour or 2. I bought a 10a circuit breaker (which I learned about by researching here), but it trips instantly and then I have to wait for the 5-6 seconds before I can try to start again and sometimes several times. I thought the cb would allow my gauges to work, but I dont have any working gauges. Is there anything else I should try. I am ready to haul it in to the dealer and see if they can fix it.
   / B7800 blowing #2 10a fuse help #2
Dealer is just going to start tracing the wires from point A to B looking for a spot where is worn through the protective cover causing it to short out. Instead of paying him $90/hour... I would start doing the same thing. Trace wires back and forth. If it's shorting out, get a few extra eyes and hears to help find it. Maybe even do it in the dark.
What does it look like behind the gauges? a mouse nest?
   / B7800 blowing #2 10a fuse help #4
There's no easy way around it. You'll have to go to the dealer and get the wiring diagram for that circuit (if you haven't already) and find everything on it and unplug each one to see if your CB stops tripping. If that doesn't work then you have a wire shorting out somewhere. Like TEG said, maybe a mouse did a little chewing or it could be something is rubbing on the harness and has made it's way through the insulation down to the copper wire.
If you bought it used it's also possible someone tried adding something extra to that circuit and then removed it before selling it and just cut the wire and didn't seal the end. I'm guessing that if you bring it to the dealer they are going to do the same thing. But if the harness is bad they will replace it where as you could fix it and save some money.
OK. Thanks for the input. I will try the in the dark idea tomorrow and I will look for a mouse nest!:laughing:
2015 FREIGHTLINER CASCADIA DAY CAB (A51222)
2015 FREIGHTLINER...
PALLET OF SQUEEZE OFFS (A50854)
PALLET OF SQUEEZE...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
