B7800 and Woods 6500 BH Combo
   / B7800 and Woods 6500 BH Combo #1
Temp97
Western New York
Waiting on delivery of my new B7800 and need to know if it's OK to use the BH with just the 3 point hitch or should I continue to use the sub frame I have. I'm sure that it's alot easier putting it on and off using the 3 PT hitch? Any thoughts.
   / B7800 and Woods 6500 BH Combo #2
The subframe is much stronger and will protect your tractor. The 3 point is likely to stress the tractor if the backhoe is used very heavily. I have a Woods BX 7000 on a subframe.
   / B7800 and Woods 6500 BH Combo #3
I've used the Woods hoes with and without a subframe. If your subframe will work, use it. Regardless of the size of the tractor it provides a stronger linkage to the tractor than just the 3PH. Benefits all over the place...
   / B7800 and Woods 6500 BH Combo #4
You won't have any problems using the 3pt attachment unless you are digging in REALLY bad stuff. Make sure you have the heavy top link installed and you will be fine. Subframe is better but not always necessary. My 3pt mount does fine and I can't imagine what it would take to torque out the frame with it! :eek: Kubota makes 3pt BH for this tractor so it's approved by them, who better to say what will work! :)
That was my thinking. If the sub-frame I have fits I'll probably keep using it but I dread the thought each time I have to put the BH on!
   / B7800 and Woods 6500 BH Combo #6
Just a note, I have a B7800 and a Woods BH-70X with the subframe, there is no need to remove the subframe once mounted on the tractor. It is compatable with my Kubota 60" MMM and FEL/ subframe. Matter of fact it is even compatable with the Kubota subframe for my front snow plow blade or front snow thrower. At times I have all three frames on at once and all are compatable with each other. A nice design by Kubota and Woods.
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
FAKE (A52472)
FAKE (A52472)
New Harvest T852 8"x52' Transport Auger (A50774)
New Harvest T852...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
1274 (A50490)
1274 (A50490)
