B7800 4x4 2007 how to remove front drive shaft
   / B7800 4x4 2007 how to remove front drive shaft #1
ohiojim
my b7800 makes a GRRRRRRR noise coming from drive shaft dealer took it apart about 5yrs back said was full of weeds . must not have been a big job. I live 1hr away from dealer and called when I got home said was fixed .told me the cover over the shaft was stuffed with weeds. its doing it again. I,m handy and do it myself with a little guidance. any help appr.jim
   / B7800 4x4 2007 how to remove front drive shaft #2
Not a lot of 7800s on here. Even less with owners that would do this project.
I can't imagine it's that hard to remove the cover. Crawl under there and take a look. Post pics if you get stumped and can't figure it out.
   / B7800 4x4 2007 how to remove front drive shaft #3
I have a 2003 B (FIRST model year), never heard of this issue before. I'll have to take a look at mine and see what is going on down there.
   / B7800 4x4 2007 how to remove front drive shaft #4
From the B7800 service manual.
   / B7800 4x4 2007 how to remove front drive shaft #5
I just finished replacing a drive front drive shaft on a B7800. The dealer says you have to pull the tranny and the loader frame (at least 12 hrs labor) to access the u-joints in the drive shaft.
I took off the fender deck rubber hoping for an access panel but there wasn't one. At that point I was resigned to splitting the tractor until I remembered a 2 1/8" carbide holesaw I had which cut a beautiful access hole.
When you cut it, beware of the hydraulic line that's dead center on the point of the trans, so stay to the right and you'll be good.
These U-Joints use double roll pins, drive the inner pin out and then the outer. Slide the U joint off. I made a driver out of a pneumatic hand nailer. I originally built it for body panels but by grinding a pin from a harbor freight punch I can install and remove pins in tough access areas like underneath the tractor with a loose shaft that has a roll pin in the u-joint. To remove the large roll pin I install the pin in the hole in the hammer head, to install I removed the driver pin and the roll pins fit into the hole perfectly.
Remove the entire front axle and drain it.
Remove the two 12mm center support bolts and other clamps to remove the lower shaft and snake it out the front.
Pull out the upper shaft and remove the U-Joint . I found my u-joints were still tight but their splines were worn, the upper shaft had at least an 1/8" of slop and the center U Joint ate the plastic cover. Now it's tight, no slop.
Use plenty of grease or never seize on the splines.
One thing that will save you massive frustration is that the sliding side of the center U-Joint is INDEXED!!!!!! Even though there is no indication on the shaft there is in the female spline It will only fit one way.
Put the new upper U-joint on and slide it up into place. Connect the sliding joint and get the support ready to go back.
Move the whole thing back and connect the trans.
Install the two carrier bolts and put the rest back together.
The workshop manual for this project is absolutely worthless so don't waste your money!
   / B7800 4x4 2007 how to remove front drive shaft #6
Good info.
Did you take any pictures you could post?
If possible, perhaps you could edit your post into smaller paragraphs for easier reading.
Thanks for posting that information. Certainly helpful for those of us with B2710/B2910/B7800 tractors.
Actually I did that for my own benefit. Will post it here and save you the trouble...
B7800 front U-Joint Replacement
   / B7800 4x4 2007 how to remove front drive shaft #7
Thanks for the edit. I'll try and post some pics. It says they'll accept PNG files (it's a genius apple thing). Anyway I have some pics.
   / B7800 4x4 2007 how to remove front drive shaft #8
No luck with photos, I can email them to you and you can try to post them.
   / B7800 4x4 2007 how to remove front drive shaft #9
   / B7800 4x4 2007 how to remove front drive shaft #10
I see you figured out the picture thing. :thumbsup:
The pictures showing the position of the hole you cut will be very useful to someone trying to do the same thing in the future.
What is going on in the last picture with the vise?
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2014 Audi Q5 SUV (A56859)
2014 Audi Q5 SUV...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A55315)
2023 Kubota...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
