B7610 will not start/PTO won't shift to neutral
   / B7610 will not start/PTO won't shift to neutral #1
zigzag001
dallas
Kubota B7610
I have a B7610, PTO is stuck in gear and won't shift into neutral. Any suggestions?
   / B7610 will not start/PTO won't shift to neutral #2
The reason it won't start is because the PTO isn't in neutral.
Is there anything connected to the PTO?? A load (drag) against the PTO can prevent it from shifting.
Not anymore
   / B7610 will not start/PTO won't shift to neutral #4
You could try working the PTO shaft back and forth with a pair of channel locks while someone tries to release the PTO lever. Something has to be stuck somewhere. If that doesn't release it then the transmission case will most likely have to be taken apart.
The alternative (not recommended unless you know what you are doing) is to override the PTO neutral switch to get it running then try to work the PTO into neutral.
2013 Ford E-350 Passenger Van (A49461)
2013 Ford E-350...
19010 (A48082)
19010 (A48082)
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
1974 Ih Farmall 1066 Tractor (A50514)
1974 Ih Farmall...
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
