B7610 will not start/PTO won't shift to neutral
   / B7610 will not start/PTO won't shift to neutral #1
zigzag001
dallas
Kubota B7610
I have a B7610, PTO is stuck in gear and won't shift into neutral. Any suggestions?
   / B7610 will not start/PTO won't shift to neutral #2
The reason it won't start is because the PTO isn't in neutral.
Is there anything connected to the PTO?? A load (drag) against the PTO can prevent it from shifting.
Not anymore
   / B7610 will not start/PTO won't shift to neutral #4
You could try working the PTO shaft back and forth with a pair of channel locks while someone tries to release the PTO lever. Something has to be stuck somewhere. If that doesn't release it then the transmission case will most likely have to be taken apart.
The alternative (not recommended unless you know what you are doing) is to override the PTO neutral switch to get it running then try to work the PTO into neutral.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2000 KOMATSU VALMET 860.4 FORWARDER (A51222)
2000 KOMATSU...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
2014 Ford F-150 Pickup Truck (A49461)
2014 Ford F-150...
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
