B7610 Engine slows
   / B7610 Engine slows #1
Raddad
Michigan
Kubota B7100 & B7610
The engine on my b7610 will slow way down and then speed back up on it's own. Any hints on what could cause this.
   / B7610 Engine slows #2
Are you sure the Fuel is good?
Did you check the Fuel filter?
I'm no mechanic but I'd start there
Problem solved. I bought a new filter and when I started to unscrew the filter bowl I noticed it was wet with fuel. I tightened the clear plastic bowl and the tractor runs fine now. Thanks for your help.
   / B7610 Engine slows #5
Glad you got it figured out! :D
2014 John Deere 6125R Utility Tractor with loader (A50657)
2014 John Deere...
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
