B7610 Engine slows
   / B7610 Engine slows #1
Raddad
Michigan
Kubota B7100 & B7610
The engine on my b7610 will slow way down and then speed back up on it's own. Any hints on what could cause this.
   / B7610 Engine slows #2
Are you sure the Fuel is good?
Did you check the Fuel filter?
I'm no mechanic but I'd start there
Problem solved. I bought a new filter and when I started to unscrew the filter bowl I noticed it was wet with fuel. I tightened the clear plastic bowl and the tractor runs fine now. Thanks for your help.
   / B7610 Engine slows #5
Glad you got it figured out! :D
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A49461)
2012 Ford F-550...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
1268 (A50490)
1268 (A50490)
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
