B7610 Engine slows
   / B7610 Engine slows #1
Raddad
Michigan
Kubota B7100 & B7610
The engine on my b7610 will slow way down and then speed back up on it's own. Any hints on what could cause this.
   / B7610 Engine slows #2
Are you sure the Fuel is good?
Did you check the Fuel filter?
I'm no mechanic but I'd start there
Problem solved. I bought a new filter and when I started to unscrew the filter bowl I noticed it was wet with fuel. I tightened the clear plastic bowl and the tractor runs fine now. Thanks for your help.
   / B7610 Engine slows #5
Glad you got it figured out! :D
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
19008 (A48082)
19008 (A48082)
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
