B7510 Mower?
/ B7510 Mower? #1
Zoomie
Texas
Ford 1700
Is the factory 60" MMM for the B7510 a suspended design or is it designed to roll over the ground like most of the after-market rear mount finish mowers?
My wife is pushing me towards a new tractor, and I'm looking at the CUTs right now... (currently comparing the B7510 to the CK20)
I know most of the subCUTs, like the BX2230 use the suspended design for their MMMs.
Thanks in advance.
/ B7510 Mower? #2
The 7510 uses a ground following deck, not suspended like the BX series. The 7500 series is an excellent machine, if I didn't require mainly a great mowing machine, I would have bought another B7500-7610, instead I bought the BX23.
/ B7510 Mower?
BotaGuy,
Thanks. I had about convinced myself to skip the new tractors, but my wife is concerned with the age of ours and now is a great time for us to buy.
I looked at the BX series, and I like them, but their limited ground clearance continues to nag at me, even though I don't have any rough terrain to maintain anymore. {shrug} /forums/images/graemlins/smirk.gif
/ B7510 Mower? #4
I getting Dejavu. Yes, it is a "roll over the ground" type. J
/ B7510 Mower? #5
Zoomie
The belly mowers for the B series tractors are ground contact decks except the RCK54-75B which is a suspended type that fits the B7510DT/HSD. It isn't compatable with the Heavy Duty Backhoe top link though. Hope this helps.
Lewis
/ B7510 Mower? #6
The 54" Deck option of the B7510 IS A SUSPENDED type mower. The 60" decks are of the ground-contact type. I am looking into the 54" right now as my yard is really bumpy and I am thinking a 54" would serve me better. If I could sell the 60" without taking a bath, I would consider it.
/ B7510 Mower? #7
OOPS! I didn't scroll down far enough. Sorry. /forums/images/graemlins/frown.gif
/ B7510 Mower?
Thanks folks,
That's just what I needed to know... another question for those who use their B series to mow with:
In terms of ground speed while mowing (I know its dependent on terrain smoothness), can you get a good looking cut at graond speeds that are higher than most conventional "Lawn Tractors" (ie MTD, Murray, etc.)?
Thanks again
/ B7510 Mower? #9
You will see from my recent past posts, I am concerned with the results I get from my ground-contact 60"MMM on my B7500. It mows nice on flat ground, but I have a bumpy lawn. That is why I may consider the BX Series, or a 54" MMM on by B7500. The quality of cut is still good, but not a "Hollywood" lawn. As far as speed, I usually cut in low range with the hydrostat pedal to the floor. In bumpier areas, I give it less go pedal. The nice thing about the B7500 is the tire size as they really absorb the small bumps a BX orsmaller-tired unit would not. Many bumps come out in spring after the winter freeze here, and they are small bumps, but frequently spaced. The large diameter tires on a B Series make the unit bounce less. I really noticed that last week wehn I test drove a BX2230. I think a suspended deck (54") on a B-Series would produce a better cut than a BX with a 60" suspended due to sheer wheelbase and tire diameter of the B. Finally, you will cut quicker due to the amount of distance you can cover with the larger tractor. This is due to the larger tires soaking up the bumps a little tired tractor (like a Murray) would not. Weight also plays a role here, too... Less bounce. And finally, a 60" deck over a 36", 42", or a 48" will certainly mean a bunch as it covers more area . I lost 1-1/2 hours on my lawn going from a 42" garden tractor to the 6" Bota. Hope this helps.
/ B7510 Mower? #10
I do most of my mowing at 2000 RPM and I run in high range at about 6 MPH, sometimes faster, sometimes slower, and the speeds for cutting are about the same, perhaps a tad faster with the BX. Max speed on the 2410 I think is around 10MPH, that is to fast for mowing. J
2011 Ford F150 (A66408)
2011 Ford F150...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2005 DRAGON 130 BBL STEEL VACUUM TRAILER (A65643)
2005 DRAGON 130...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
