B7510 HST won't start
   / B7510 HST won't start #11
Well it looks like 10 has sheared the head off and 70 is hangin in the wind. Although with all the grit & oil it's kinda hard to tell.
   / B7510 HST won't start #12
I just posted this to the B7800 with the same type of problem, i don't know if it will work on the B7510 but looking at the pictures you have they look very similar. Here is what i posted, hope it helps.
I recently had the same issue with my B7800. Look under the hydro peddle and you will see a rod that goes to a rubber boot. When you press on the peddle you should see a small steel cylinder that moves in and out of the rubber boot, that was where my problem was. Now the time consuming expensive part. You will need a can of WD-40 or an equivelant. Spray the steel cylinder with the WD-40 and press the peddle, do this a couple of time and your issue will probably be resolved, atleast it worked for me. I think the cylinder binds up on the ruber boot causing the safety switch not to engage.
I hope this helps.
Good Luck,
Piper
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2014 Jacobsen AR3 Commercial Mower (A50322)
2014 Jacobsen AR3...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
