B7510 Clutch problem
/ B7510 Clutch problem #1
CBW1999
Platinum Member
Northern Vermont on the 45th parallel
Kubota 7510, Toro Groundsmaster 217D
Kubota B7510 Gear transmission. 8 Years old and just about 500 hours
Original issue: Slight gear grind when shifting with clutch depressed fully. :(
Action: Adjusted clutch linkage to within specs. In doing so, had to remove entire linkage to free up frozen adjusting nut. :mad:
Current issue(s): Slight gear grind remains, can now shift without using clutch. Tractor does NOT move when in gear AND clutch fully depressed. When PTO Lever ENGAGED-continues to spin when clutch depressed fully. Can engage PTO without using clutch. When PTO lever NOT engaged, PTO does NOT spin. :eek: :confused:
No odd associated sounds or smells. :confused2:
Yes, I know....... most likely.....I screwed the pooch somehow:laughing:
Any other ideas?
Thanks in advance
2022 EZ-GO ELITE...
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
2019 CATERPILLAR 299D3 SKID STEER (A65053)
2019 CATERPILLAR...
40ft High Cube Shipping Container (A64553)
40ft High Cube...
(2) COLE FERTILIZER DISTRIBUTORS (A64278)
(2) COLE...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
