B7500HSD with FEL
/ B7500HSD with FEL #1
Spud
Moncton, New Brunswick, Canada
2001 Kubota B7500HST
Hi
Anyone know what the length of a B7500HSD & LA302 Fel would be? I need to figure this out before I have a trailor made to haul the B7500HSD and Fel. Guess I should most likely add some length for a rototiller or backhoe also.
Spud
/ B7500HSD with FEL #2
Spud
Check out this thread on Trailer spec's. There is a lot of information on how to spec a trailer. My guess would be 16 to 18' by maximum width between fenders 7'6".
/ B7500HSD with FEL #3
I use a common style dual-axle trailer with a 16' x 6.5' floor. My B2150HSD w/FEL should be only slightly longer than a B7500.
The tractor/FEL/60" Landpride finish mower goes from the front rail to the rear edge.
The tractor/FEL/rotary mower hangs off the trailer by the length of the rotary mower's tail wheel.
I have had no problems with the 6.5' width; however, I did refuse to buy a new 6' wide finish rear-discharge mower because it was 1" too wide for my trailer (this allowed me to jump on a great deal on the used 60" side discharge Landpride mower).
Therefore...
Length: Get at least 16 feet.
Width: 6.5 feet should work for the rototiller and back-hoe. A 6' landscape rake or a 6' scraper blade should fit with narrow clearance. You probably shouldn't be using 6' mowers on the B7500 so that shouldn't be a problem.
Kelvin
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
20 Ton Hydraulic Bottle Jack (A64127)
20 Ton Hydraulic...
2015 Polaris Sportsman 570 AWD ATV (A64557)
2015 Polaris...
Big Star Sign (A64127)
Cattle Feeder (A65640)
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59914)
2021 KENWORTH T680...
