B7500DT
/ B7500DT #1
mainiac
Why would my front tires spin and my rears won't when pulling on logs? But all is fine when there is no load on the tractor.
I jacked the tractor up and all seems tight.
Is the front end driven differently than the rear as far as the clutch is concerned (ie a seperate electronic controlled clutch or gear)? The rear end acted like the clutch was slipping, but the front acted strong.
Any ideas?
Thanks
Mainiac
This is a Kubota tractor
/ B7500DT #2
I'm going to guess you don't have a loader or front weights on your Kubota.
When you're dragging logs, there is a weight transfer to the rear. Less weight on the front axle results in less traction, hence the spinning.
That's my guess...
/ B7500DT
Would not operate a tractor with out a FEL. I do have a FEL plus a 60# front bumper. Rears would just stop spinning while fronts marched on.
Thanks
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
832627 (A61166)
832627 (A61166)
1459 (A57192)
1459 (A57192)
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2018 HINO SA (A58214)
