B7500DT
/ B7500DT #1
mainiac
Why would my front tires spin and my rears won't when pulling on logs? But all is fine when there is no load on the tractor.
I jacked the tractor up and all seems tight.
Is the front end driven differently than the rear as far as the clutch is concerned (ie a seperate electronic controlled clutch or gear)? The rear end acted like the clutch was slipping, but the front acted strong.
Any ideas?
Thanks
Mainiac
This is a Kubota tractor
/ B7500DT #2
I'm going to guess you don't have a loader or front weights on your Kubota.
When you're dragging logs, there is a weight transfer to the rear. Less weight on the front axle results in less traction, hence the spinning.
That's my guess...
/ B7500DT
Would not operate a tractor with out a FEL. I do have a FEL plus a 60# front bumper. Rears would just stop spinning while fronts marched on.
Thanks
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
208320 (A58375)
208320 (A58375)
New/Unused SD Lanch SDLD25 Mini Crawler Dump (A61166)
New/Unused SD...
2013 Mercedes-Benz E-Class Passenger Car, VIN # WDDHF5KB8DA693077 (A61569)
2013 Mercedes-Benz...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59908)
2012 INTERNATIONAL...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
