B7500DT
   / B7500DT #1
mainiac
Why would my front tires spin and my rears won't when pulling on logs? But all is fine when there is no load on the tractor.
I jacked the tractor up and all seems tight.
Is the front end driven differently than the rear as far as the clutch is concerned (ie a seperate electronic controlled clutch or gear)? The rear end acted like the clutch was slipping, but the front acted strong.
Any ideas?
Mainiac
This is a Kubota tractor
   / B7500DT #2
I'm going to guess you don't have a loader or front weights on your Kubota.
When you're dragging logs, there is a weight transfer to the rear. Less weight on the front axle results in less traction, hence the spinning.
That's my guess...
   / B7500DT
Would not operate a tractor with out a FEL. I do have a FEL plus a 60# front bumper. Rears would just stop spinning while fronts marched on.
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
INSPECTION (A51572)
INSPECTION (A51572)
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
UNUSED AGT MXMRW14 STAND ON WHEELED SKID STEER (A51243)
UNUSED AGT MXMRW14...
Excavator Bucket (A50514)
Excavator Bucket...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
