B7500
/ B7500 #1
MikeFLA
Central Florida
Kubota B7500
Like many of you, I have struggled with the BX2200 vs. B7500 buying decision. After reading many of the posts and looking at this thing every which way, an analysis of the specifications from the Kubota catalog proved helpful. This is what I’ve found.
· The BX2200 is approximately 18% less expensive than the B7500 *(Local dealer quote)
· The BX2200 has 4.5% more horsepower than the B7500
· The BX fuel tank capacity is 15% less than the B7500
· The BX2200 hydraulic pump output is 27% less than the B7500 *(B7500 utilizes a dual pump system
· The BX2200 lift capacity at lift point is 12% less than the B7500
· The BX2200 lift capacity 24" behind lift point is 56% less than the B7500
· The BX2200 has a 7% shorter wheelbase
· The BX2200 is 5% lighter in weight than the B7500
· The BX2200 loader lift capacity at (bucket center) is 29% less than the B7500 *(LA211 compared with LA272)
· The BX2200 ground clearance is 79% less than the B7500 *(assuming both specifications are with turf tires)
Based on the "buyers" objectives this information could help point to an alternative.
· For instance, if initial cost is an issue, the BX is more attractive.
· If lift capacity is a concern, the B7500 is a better choice.
· If increased loader capacity is important, you may want to consider the B7500.
· If ground clearance is a must, then the B7500 performs better.
· If a low center of gravity (stability) is important, the BX is favored.
For me, lift capacity and ground clearance are important objectives and therefore I lean toward the B7500.
Mike
/ B7500 #2
Analytical Mike/w3tcompact/icons/wink.gif
Take a look @ the spread sheet that GluGuy provided for the B series comparision.
(You will love it) You can find it in "forum feedback-excell spread sheet", under his post. It will give you a better insight for the hp comparision.
BTW which tractor do you LIKE
Al
/ B7500 #3
<font color=blue>The BX2200 has 4.5% more horsepower than the B7500</font color=blue>
I take issue with that one. Actually, it's more like the B7500 has 20% more HP than the BX, if you look at it at comparable RPM. See my spreadsheet that I did entitledKubota B series comparison. The engine comparison is color-coded to show general power range (1800-3600 RPM) in yellow, "advertised" HP/torque in blue, and PTO range (outlined with bold black). You'll see that the B7500 and B2710 have the broadest power range, but that there is a general increase of 4ft-lbs of torque per 100 CC of engine displacement.
A better comparison of power is probably the torque though; because fewer "games" can be played with the number. Again, the B7500 has roughly 10% more torque than the BX.
The ground clearance by itself is not a big deal. However, it can make a difference depending on the type of implements you intend to put on the 3PH.
Full disclosure: I love <font color=orange>Lucy!</font color=orange>
The GlueGuy
/ B7500
Thats what I get for taking factory specs at face value. You would think they would help you out when comparison shopping by publishing apples for apples.
The ground clearance thing is clearly an issue for me. I use my tractor to launch my ski boat and can use all the help I can get.
Thanks for your insight
Mike
2017 Eager Beaver 20XPT 27ft 24 Ton T/A Tag Trailer (A66736)
2017 Eager Beaver...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2016 Ford Escape AWD SUV (A66738)
2016 Ford Escape...
2014 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2014 (INOPERABLE)...
PORTA POTTY (A68842)
Unused 2025 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2025 USA...
