B7500 won't start - interlock?
/ B7500 won't start - interlock? #1
zeke7237
I've read the other "won't start" threads, but nothing there seems to apply to my older B7500HST. No seat interlock, no fwd/rev, clutch, pto interlocks that I can see anywhere and wiggling those levers doesn't seem to help in any case. There is an interlock relay between the keyswitch and the solenoid, and it's driven from a little electronic module behind the relay .. but what controls that relay in the 7500? It's been about a year since I could start it with the key .. I've been hotwiring the solenoid. Keyswitch is OK, relay looks good (coil resistance is normal). Any clues?
/ B7500 won't start - interlock? #2
If it it a hydrostatic drive try rocking your hydrostat pedal back and forth allowing it to find it's sweet spot. There is a safety interlock there. Work with it a little. Patience.
/ B7500 won't start - interlock? #3
zeke7237 said:
I've read the other "won't start" threads, but nothing there seems to apply to my older B7500HST. No seat interlock, no fwd/rev, clutch, pto interlocks that I can see anywhere and wiggling those levers doesn't seem to help in any case. Any clues?
Zeke7237 - My 2003 B7500 HSD has three interlocks: Clutch pedal must be depressed. Speed control (foot) pedal must not be pressed (neutral position). PTO gear shift lever must be in neutral position.
Best Wishes, Rusty
Yah, I found the pto and clutch switches, still looking for the fwd/rev. Looks like the clutch and PTO are both way out of adjustment.
Anyone need a spare keyswitch? I've got an extra one I don't need :(
/ B7500 won't start - interlock? #5
Is it free? Does it come with the B7500? :)
I've never had a problem with mine starting except the typical levers etc in the wrong position, best of luck on figuring it out.
/ B7500 won't start - interlock? #6
My 03 B7500 has only done this once and I found out that the PTO (540) was enguaged by mistake when I got off of it.It took me until the next day to figure it out.Simple mistake......
Donny
No, but I'll make a good deal for someone .. messicks won't take back electrical parts :(
I got it going this evening .. the PTO switch was way out, I had to move it almost all the way in to get it to hit. Clutch switch was way out too, but I was able to just bend the contact plate up a bit. Starts just fine now!
2013 MACK CHU613 (A67714)
2013 MACK CHU613...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
1 PALLET OF HYDRAULIC HOSES (A66091)
1 PALLET OF...
2017 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A69167)
2017 FREIGHTLINER...
