B7500 Wheel Width
/ B7500 Wheel Width #1
Steuben
B7500 HST
Hi, I just picked up a slightly used B7500 and was curious as to what was the wheel width most people have them set at. I'm new to tractors and would appreciate any help and advice from the experienced. Thank you.
/ B7500 Wheel Width #2
Do you have a loader ??? What type of tires ????
PS It helps if you fill in your profile a bit.
/ B7500 Wheel Width
Thanks for the response, just bought the tractor and I registered before trying to figure tractor stuff first then I'll tackle profile. I have Ag tires and a 302 loader.
/ B7500 Wheel Width
Thanks for the response, just bought the tractor and I registered before ,trying to figure tractor stuff first then I'll tackle profile. I have Ag tires and a 302 loader. Check that, profile worked.
/ B7500 Wheel Width #5
My rear wheel are set wide for stability, I have the same tractor and loader.
Daniel
/ B7500 Wheel Width #6
When I bought my B7500 the wheels were all the way out. I moved them in one hole on each side. After putting my MMM on there it was just right. I have R-4 tires on mine. These are tough little tractors.I'm on mine almost daily.
Donny
/ B7500 Wheel Width #7
Steuben, Where are you from?
Donny
/ B7500 Wheel Width
Don, I'm from NY about 70 miles north of NYC but don't hold it against me.
/ B7500 Wheel Width #9
I would have to look at the manual but I would set them to be 48" outside measurement so they are as wide as the bucket. There are sveral combinations of wheel in/out and or hub in/out as well as the axle positions.
/ B7500 Wheel Width #10
I am contemplating a b7500 at a foreclosure auction, but it's a little narrower then my current b9200. How wide can the rear wheels be placed without modification? How wide can they be placed without modification? I have some steep angles that I mow on, and am concerned about the instability of a narrow tractor. Thanks for your help!
PORTA POTTY (A68842)
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2025 JMR Stump Bucket Skid Steer Attachment (A66734)
2025 JMR Stump...
2012 KAUFMAN PAVER DELUXE PINTLE HITCH TRAILEF (A67714)
2012 KAUFMAN PAVER...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
