B7500 vs B2410
/ B7500 vs B2410 #1
Westbilly
SC
2410 HST FEL LA352
I have decided to buy a Kubota! Now which one? Is the 2410 worth 1500 more dollars. You get the position control, 4/2 more HP, and 110 lbs. more weight. Decisions decisions...
/ B7500 vs B2410 #2
And about the only way I'd know to decide which one is to drive both for awhile and see if you think the 2410 is 10-15% better than the 7500./w3tcompact/icons/wink.gif I think it would be to me, but since they're both nice machines, it just depends on your uses and what's comfortable for you.
/ B7500 vs B2410 #3
Also remember to factor in the increased cost of some of the implements. I jumped from the BX to the B7500 and while the cost difference betweer the tractor was only $1500 the larger implements cost me another $1500.
Jeff
2001 B7500HSD, LA302 fel, 60"mmm, grass catcher
/ B7500 vs B2410 #4
Implement cost between these two models should not really efect price, Anything bought for a 7500 will work on a 2410. Now the 2410 should be able to handle slightly larger....
/ B7500 vs B2410 #5
Yeah, I guess the loader would be the only different model which might command a slightly higher price.
Jeff
/ B7500 vs B2410 #6
Part of it depends on what you want to do. The 2410 has some nicer features besides horsepower. Position control is a big one if you plan to do leveling and grading. I can't imagine attemping to make the "fine" adjustments with the "up/down" on the 7500.
If you do go with the 2410 don't bother with "bi-speed turn". I have a 2400 (I bought it used) with bi-speed turn. I can't find where is does anything for me.
/ B7500 vs B2410 #7
Westbilly,
It's a marginal call IMO. The engine in the 2410 isn't all that much stronger than the 7500, and they are pretty much the same frame. If you want a stronger/bigger tractor, I'd look at the 2710 or 2910, both of which are on a bigger frame and have a distinct increase in power.
I've heard all the arguments about position control. I have a B7500 w/o it, and haven't had a problem, even though one of my primary uses is the boxblade. I guess if you've never had it, you don't know what you're missing.
The GlueGuy
/ B7500 vs B2410 #8
<font color=blue>1500 more dollars</font color=blue>
That's a good price differential. When I got firm quotes, the difference was $2,300.
/ B7500 vs B2410 #9
I had a similar experience as fishman; the difference between the 7500 and 2410 was roughly $2,200 when I priced the units last year. I ended up going with the 7500 and bought a pto chipper with the savings. However, if the difference was $1,500 I think I would have gone with the 2410.
AC
2002 Lexus RX 300 SUV (A66738)
2002 Lexus RX 300...
10ft S/A Cargo Trailer (A66738)
10ft S/A Cargo...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
2004 Toyota Sienna Van (A66738)
2004 Toyota Sienna...
1997 Angler 220 Walkaround Boat with T/A Aluminum Boat Trailer (A66738)
1997 Angler 220...
