B7500 & trailer?
/ B7500 & trailer? #1
Darins
Stanwood Wa.
B7500
I have a ? I need to get a trailer for my B7500 so I can move wood around my property. But I don't know how big of a trailer my tractor will pull or how many #? I don't want to get something to big and run it in the ground. I have 5 acre and when I need wood it just take too many trips to move it around in the loader so I thought a trailer would help. Thanks again for all your help.. Darin
/ B7500 & trailer? #2
Darins, if I remember right, my B7100 manual said it would pull a 1,000# trailer, but you have to remember that trailer towing ratings take into consideration things like brakes and the ability to stop a trailer. You can actually pull a lot more if you go slowly, don't have so much weight on the tongue that the front wheels get too light to steer, etc. I have a 5' x 10' tiltbed trailer that I've used a lot to haul limbs, brush, etc., but of course that wasn't nearly as heavy as firewood. Tractors are made for pulling, so I don't think you'll hurt your tractor. It's just a matter of staying small enough that you can control the trailer.
Bird
/ B7500 & trailer? #3
Darins-
When I got my L3000 the manual said how heavy of trailer I could pull. Maybe the b7500 manual is different.
Not much info, but hopefully that helps/w3tcompact/icons/smile.gif.
Paul
/ B7500 & trailer? #4
There use to be a old rule of thumb around these parts.
Buy or build a trailer in which the tractor can be transported in,also floation tires do work the best when the ground wet.
Have you consider if you want the trailer w/a dump body.
Thomas..NH /w3tcompact/icons/wink.gif
/ B7500 & trailer? #5
I carry my firewood (about 6 cords a year) in my FEL and on a 3 pt carryall that I built. For me, using the FEL/carryall combo instead of a trailer allows me much greater freedom to move around in the woods (I have fairly thick woods). Also, I built my carryall for no $$ using stuff I had laying around. Using this combo may not work for you, but it has worked well for me so I thought I'd toss it out.
Corm
<P ID="edit"><FONT SIZE=-1>Edited by corm on 03/17/01 08:17 PM (server time).</FONT></P>
/ B7500 & trailer?
Thanks Corm, If you have any pictures of that carryall I would really like to see them. How big is it and what did you build it out of? Thanks again.
/ B7500 & trailer? #7
Darins - I don't have a picture, and right now it is buried in my shed and won't see daylight till the snow melts around here (could be awhile - we are supposed to get up to another foot on Thursday). I built it all out of wood. I didn't have a welder or any welding skills at the time (I recently went to a welding class and have bought a MIG welder, so I'm dangerous now). It is 5 foot square. I built the bottom framework out of hardwood, using 4x4s for the perimeter, and 3x3s for the cross pieces. I used maple boards for the 'deck', and 1/2 inch plywood for 3 sides. The sides are about 30" high. The whole thing sits on the lower arms of my 3 point hitch, and is held in place by a couple of short pieces of hardwood. It is more rugged than it needs to be, but I wanted to make sure it would hold a load of green firewood. I also built a plywood bottom for my bucket, extending the bottom of it and effectively doubling the size of my bucket. Between the bucket and what I can get on my carryall, I can carry one run (1/3 of a cord) all cut and split. Two trips in a day and I'm ready for a cold one...
Corm
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
John Deere 4044M (A60462)
John Deere 4044M...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
Case skid steer wheels and tires (A63689)
Case skid steer...
