Mowing B7500 Sickle Mower
/ B7500 Sickle Mower #1
Doty
JD 2320. X530
I've searched the forums, I've done some homework, now I'm looking for some more opinions on a specific setup. I'm looking to mow some steep embankments with a B7500 and a sickle mower. It seems to me that a belt drive is the only way for me to go since I want to mow below vertical. I also understand some limitations on the offset weight and that the horsepower requirement is negligable.
So now I'm asking, which would you buy and why? How about a tow behind?
Other suggestions please...
/ B7500 Sickle Mower #2
I use an AC (old model) 3pt on my Kubota L4200... it is a 7 ft.
I've rigged it up to hydraulically swing from 90 degrees Up to near 90 degrees Down. There are a few ways to do a belt drive, I think AC had the Best.
3pt is the handiest but a trailer type will work, but it's not as agile, can be a bit cumbersome.
I use my AC to side trim Hedge trees and do very deep ditches, and around my pond... works great. KennyV
/ B7500 Sickle Mower #3
The only mowers I have experience with are the New Holland 450/451 (3pt) and equivalent trailer type (model 455 I think). For this size tractor the trailer type are going to be the easiest to setup/hook up, provided you have a hydraulic remote valve on the tractor. Just drop in the hitch pin, hook up the PTO shaft and hydraulics and you are ready to mow.
I have a 451 model which is 3pt hitch type. To use it on a B-series Kubota you need the optional toplink adapter for compact tractors. I made my own and it was fairly straight forward if you have welding capabilities. The 3pt hitch mower is more compact and maneuverable, but also harder to hook up. I was worried about the weight, but my B3200 handles it fine, even on moderate slopes. If you get on a steep slope with the mower on the down hill side, you have to be careful, but for all of my uses (mowing hay, around the ponds, etc) it works fine.
I don't have any experience with one, but one of our neighbors used a Ford 501 sicklebar mower on a B-series Kubota, seemed to work fine as well (but is not belt drive.) Regardless, stick to a maximum of 7' cut or less, the 9' mowers are way to much for this size tractor.
Attached are a couple pics of my tractor with mower (mowed about 15ac of hay with it that day.)
How about a Ford 515? What's so bad about them? I found one today in decent shape for $350.
Thanks for the informative replies so far.
/ B7500 Sickle Mower #6
Do you guys think my bx-24 could handle a 7ft cycle mower? I have some steep banks and a 1 acre pond and I think it would be easier to mow with one? Thanks
/ B7500 Sickle Mower #7
A few years ago I bought a John Deere 350 9' belt drive sickle mower for a Kubota B2400. The JD is quite heavy (650#), even for a belt drive mower. The three point hitch would lift the weight okay, but the offset nature of the weight put a great sideways strain on the TPH that I felt would probably break the rockshaft at some point. So I build a subframe for the mower that carries all the weight from the rear axle housings and it works great. It cuts even heavy weeds at full speed in low range (about 2 1/2 acres/hour) without any strain.
2012 Ford Expedition SUV (A61574)
2012 Ford...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
2020 McCloskey R155 Trommel Screener (A61572)
2020 McCloskey...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
2022 EZ-GO ELITE...
