B7500 Main shift arm replacement help needed
/ B7500 Main shift arm replacement help needed #1
OzRange
Pemberton, NJ
B7500
I replaced a broken main shift arm and put top section back on (part with 4 bolts), but gears are not working properly. Shifter only moves to a couple of positions and seems to be in some gear, but acts like locked in gear with the brake on. Anyone have pics of the position of the shift forks, gears before closing this up.
/ B7500 Main shift arm replacement help needed #2
When you set the transmission cover down you need to make sure that every shift fork slides into it's corresponding slot in the corresponding synchronizer hub. Otherwise you will have the symptoms you are describing. The transmission is probably in two different gears at once which is why it feels locked up.
in 2 gears - symptoms sounds about right. I just sent a huge splinter up inside my foot-going to ER, so cant do it tonight. Thanks for the quick advise.
going tonight to get back into the gears, but - when I originally put it back together, i aligned each fork (2) over the 2 different sized gears. I guess that is incorrect. How should I align it. I don't recall seeing any "slots". Does anyone have a pic? Thanks.
/ B7500 Main shift arm replacement help needed #5
This is way back in 2014 but what was the outcome of this. I literally just did the same thing as in this post. There is only 2 positions for the shift forks. Only going into 2 gears.
/ B7500 Main shift arm replacement help needed #6
Caterpillar 345B/BL Excavator Service and Parts Manuals (A63117)
Caterpillar...
2016 Great Dane 50ft. T/A Refrigerated Van Reefer Trailer (A61573)
2016 Great Dane...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61572)
2025 Wolverine...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
