B7500 Hydraulic Fluid
/ B7500 Hydraulic Fluid #1
Anonymous Poster
Epic Contributor
Need to change the hyrdaulic fluid on my B7500HSD for the
first time - 66 hours.
I can't tell very well from the manual exactly where the drain
plugs are. It appears that there are two - one right on the
side of the mid-PTO and one to the bottom left of the
filter. There are a few bolts next to the filter though; I'm
not sure which is the drain plug.
Can anyone confirm that:
(a) there are only these two drain plugs
(b) which bolt next to the filter is the correct one (I assume if
I unscrew the wrong one, which I would know if no fluid
came out, that I wouldn't harm anything).
The manual indicates about 3.3 gallons of Hydro fluid; is that
about how much will drain out? I would assume that it would be less because not all of it would drain out.
/ B7500 Hydraulic Fluid #2
I just did the 50 hr. service on one yesterday. I drained the trans. in 4 spots. The one next to the mid PTO, one on each side of the rear axle housings, and one on the clutch housing even though very little fluid comes out after draining the other places. 3.3 gallons isn't very far off it might be 3 gals. The drain plugs will have a slightly different head on them compared to the housing bolts.
Brian
Thanks for the response.
Does (will) most of the fluid come out through the PTO drain plug? Just wondering in case I
can't locate the other three that you mention.
I don't know why Kubota can't mark these a little better.
/ B7500 Hydraulic Fluid #4
Yes, most of the oil will come out at the mid PTO but you do want to try to get the ones on the rear axle housings. There is enough oil there to make it important, especially on the first oil change. I hope you know about removing the suction screen and cleaning it also. It is on the right hand side of the transmission case in front of the rear axle housing. I like to put some red paint on the drain plugs when I have them out so there are no problems the next time.
Brian
/ B7500 Hydraulic Fluid #6
Brian,
I just changed the oil in my B7500 a month ago and knew nothing of the suction screen. Where is it and should I clean it or can I wait for the next scheduled oil change?
Thanks,
AC
I did the hydro oil change over the weekend on my B7500HST.
Two questions came up:
(1) The strainer - in the manual, the picture shows this to be
to the left of the filter. However, on the actual tractor, I
could not find anything looking like that on the left. There
was a tube on the right side - I took that off, but there
was no strainer (or anything else) apparently inside (ie:
there was nothing else for me to remove).
Can anyone tell me exactly where the strainer is?
(2) I had to remove my rear wheel to get the hydro filter
off. I used as a jacking point my FEL frame (the flat
part that the FEL hooks into right in front of the clutch) -
this worked great as it was the right size and seemed to
hold the tractor up securely.
I was wondering though what others use as the jacking
point if they do not have the FEL frame? I initially was
going to use the rear trailer hitch, but I could tell that
was going to be very unstable. The jack would not have
reached anywhere else (I use a hi-lift jack).
Fluid that came out was pretty clean; took exactly 3
gallons of new fluid - $19.38 per gallon Super UDT.
Thanks.
/ B7500 Hydraulic Fluid #8
You can probably wait till the next oil change to clean the screen. It is located on the right side of the tractor in front of the rear axle housing. It looks like a big bolt going through the hydraulic line. It has a 26 mm head on it. Hope this helps.
Brian
Thanks Brian....I'll take a look for it this weekend. Sure wish the Kubota manuals were a little more
detailed, would make it easier for non-mechanical novices such as myself.
/ B7500 Hydraulic Fluid #10
Are there service manuals available? Sort a Kubota's for Dummies.
Bluegrass, Pick It Up!
/ B7500 Hydraulic Fluid #11
Snowman,
<font color=blue>$19.38 per gallon Super UDT.</font color=blue>
I think your dealers is getting a lot for UDT./w3tcompact/icons/frown.gif I pay $12.12 a gallon and have seen other posts that say about $12 a gallon.
Al
I know - not much choice though.
Actually isn't my dealer; my dealer went out of business about
three months after I purchased the tractor.
The dealer I bought the UDT from is about 35 miles away; he's
the closest one. The next closest one is about 40 miles away,
but they don't have a good reputation.
I initially used a recommended dealer that was about 100
miles away, but they could not ship oil (deemed to be a
hazardous material). Therefore, I'm stuck paying whatever
they want for however far away I have to drive.
I had purchased a Woods 5' rear blade from this dealer, and he
was about 20% cheaper than a local equipment dealer, so I
figure what I saved on the blade helps offset any increased
supply costs.
I know that I can get cheaper filters, etc. from tractorsmart.
Thanks.
/ B7500 Hydraulic Fluid #13
I pay $11.78 to $13.50 per gallon depending on which dealer I get it from. This is when I buy a 5 gallon pail. By the gallon bottle is much higher.
This dealer only had gallon jugs.
All of his Kubota supplies were quite sparse. He said that
he's had a difficult time getting parts fro Kubota.
They do have alot of Kubota tractors on their lot though.
They're a big ag dealer - huge pieces of brand new equipment
all over.
/ B7500 Hydraulic Fluid #15
I found the quickest and easiest way to get 5 gallons of Super UDT was to get it from tractorsmart.com. $60.60 Plus five dollars shipping direct from Kubota. Came by Fedex ground in two or three days.
Thanks - I'll use them the next time. The dealer that would not ship me the UDT before was using
UPS, so apparently UPS and FedEx have different shipping policies. Much easier (and cheaper) than
driving 60 miles.
17394SFL (A61568)
17394SFL (A61568)
Trailmobile Van Trailer (A63118)
Trailmobile Van...
2023 Case TV380 (A62177)
2023 Case TV380...
240 Massey Ferguson Tractor (A61165)
240 Massey...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
Fork Extensions (A61572)
Fork Extensions...
