B7500 Fuel Filter
/ B7500 Fuel Filter #1
robertm
Northern Illinois
Kubota BX2660
Has anyone had experience getting the fuel filter assembly out of the filter bowl on a 2002 Kubota B7500? After I screwed the bowl off the tractor, I had a hard time getting the white "disc" that the filter is attached to out of the bowl. I had to use a dental pick to pull it out, and risked damaging the filter. /w3tcompact/icons/shocked.gif Luckily, it worked out, but there has to be an easier way.
Thank goodness for fuel bowls and filters! I got some bad fuel that had some !@#$% that settled in the my fuel can. When I poured it into my tractor fuel tank, I noticed as I neared the last bit of fuel I was pouring, that a "silty" substance was going into the funnel. I immediately pulled the funnel out, and the screen in the funnel was clogged enough to prevent any fuel spillage as I whisked the funnel away. Unfortunately, some of the garbage did go into the tank, although I did not notice it at the time. Well, when she ran tough, I knew exactly where to look.
Two lessons:
1. Always check your fuel can before filling it, and while you pour.
2. Use a funnel with a screen
/ B7500 Fuel Filter #2
HI,
A tip that I picked up here at TBN was not to empty the fuel can into the tractor, but rather to save the last quart or so for a glass jar.
Empty the last quart of so into a glass jar, and let any water or junk settle out, before pouring the remaining fuel into the tractor.
Tried this on my first fuel up, and found a tablespoon or so of water in the remaining fuel. Second time, when using off-road fuel from another station, I found absolutely nothing but fuel in the remaining quart.
I think I will make this a standard practice at my end....simple enough to do.
Bill Macher...not too far from the Pgh, PA city limits...
/ B7500 Fuel Filter #3
I don't think there's any easier way to get that white disc out of the bowl.
I had the same problems; had to use an awl to pry the thing out.
2026 Electric Tricycle (A64194)
2026 Electric...
Street Sweeper (A60352)
Street Sweeper...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
