B7500 Fuel Filter
/ B7500 Fuel Filter #1
robertm
Northern Illinois
Kubota BX2660
Has anyone had experience getting the fuel filter assembly out of the filter bowl on a 2002 Kubota B7500? After I screwed the bowl off the tractor, I had a hard time getting the white "disc" that the filter is attached to out of the bowl. I had to use a dental pick to pull it out, and risked damaging the filter. /w3tcompact/icons/shocked.gif Luckily, it worked out, but there has to be an easier way.
Thank goodness for fuel bowls and filters! I got some bad fuel that had some !@#$% that settled in the my fuel can. When I poured it into my tractor fuel tank, I noticed as I neared the last bit of fuel I was pouring, that a "silty" substance was going into the funnel. I immediately pulled the funnel out, and the screen in the funnel was clogged enough to prevent any fuel spillage as I whisked the funnel away. Unfortunately, some of the garbage did go into the tank, although I did not notice it at the time. Well, when she ran tough, I knew exactly where to look.
Two lessons:
1. Always check your fuel can before filling it, and while you pour.
2. Use a funnel with a screen
/ B7500 Fuel Filter #2
HI,
A tip that I picked up here at TBN was not to empty the fuel can into the tractor, but rather to save the last quart or so for a glass jar.
Empty the last quart of so into a glass jar, and let any water or junk settle out, before pouring the remaining fuel into the tractor.
Tried this on my first fuel up, and found a tablespoon or so of water in the remaining fuel. Second time, when using off-road fuel from another station, I found absolutely nothing but fuel in the remaining quart.
I think I will make this a standard practice at my end....simple enough to do.
Bill Macher...not too far from the Pgh, PA city limits...
/ B7500 Fuel Filter #3
I don't think there's any easier way to get that white disc out of the bowl.
I had the same problems; had to use an awl to pry the thing out.
UNUSED SDLANCH 14' BI-PARTING WROUGHT IRON GATE (A65055)
UNUSED SDLANCH 14'...
2016 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2016 VOLVO VNL 6X4...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2024 BIG TEX 102" X 25' GOOSENECK TRAILER (A65054)
2024 BIG TEX 102"...
PALLET OF PUMPS & MISC (A64278)
PALLET OF PUMPS &...
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
