B7500 Front wheel seals
/ B7500 Front wheel seals #1
Opiekanopi
Central Kentucky
2000 B7500DT
Anyone else had trouble with their B7500 front wheel seals leaking? One of mine started leaking last fall. I had it fixed (Thank goodness still under the 3 year pwr train warranty) and two weeks after I got it back the other side is now leaving puddles in my garage. It will also be covered but I'm worried about post warranty times now.
Thanks Rick
/ B7500 Front wheel seals #2
Hmmm, nope, I haven't but...did you perchance reverse the wheels on the front to widen the tractor's stance? I've seen some people do that, but in the Workshop Manual it says not to do that.
Fortunately, I haven't had the same problem...maybe they did something wrong when they assembled the tractor in the first place?
/ B7500 Front wheel seals #3
I had 1 side start to leak. Replaced it myself because I didn't want the hassle of dealing with warranty. I did notice the new seal was heavier duty, so now I am wondering if it was a defect that Kubota bacame aware of. My tractor had over 450 hours on it and I have done lots of loader work so I'm sure the seals get a workout.
Mine has only about 170 hours on it. But some of that is pretty rough. I plow and disk with it which really bangs the front end around. I'm going to go ahead and let the dealer fix the other side and hope for the best. Was it pretty easy to fix yourself?
Oh, and No I haven't reversed the wheels.
But that makes sense not to.
Thanks,
Rick
/ B7500 Front wheel seals #5
The hardest part actually was removing the old liquid gasket. You do need a bearing puller though.
2024 John Deere TX (A64119)
2024 John Deere TX...
2016 Freightliner M2 106 Ambulance (A61573)
2016 Freightliner...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
UNUSED WOLVERINE HYD TRENCHER (A64281)
UNUSED WOLVERINE...
LOT OF SCAFFOLDING (A63291)
LOT OF SCAFFOLDING...
2012 Ford Explorer SUV (A61574)
2012 Ford Explorer...
