b7200
/ b7200 #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Looking at a b7200 4wd, gear trans. 1630 fel. 4520a hoe with its own pump. Looks like a subframe in that there is solid steel angles and bolts on the bottom but there is a adjustable link on top. Is that a true sub frame About 1100 hours guestimated. No noticable wet spots. Engine sounds good. There is some squealing when first moving the hoe. The fluid is just at the add mark. The rear wheels have a lot of corrosion at the valves and one has been welded in that area, a lot. Either holding air or have been filled. Some light cracking on sidewalls.
Any one willing to venture a reasonable value?
/ b7200 #2
Sounds like a three point hitch hoe.Probably had calcium chloride for ballast in the tires(not good if their leaking).So you are looking at ,new rims,tires.
Maybe worth $8,000 at most.
I have run a B7800 with a hoe,decent little machine, a little cramped for room on the hoe but not bad.
I know that one is a true sub-frame machine,removable with large pins.
/ b7200
I see that wheels and tires are a hard to find item for this model from that I've found here and elsewhere.
/ b7200
I've been trying to price wheels and tires for this beast and get different information. I don't really know how to classify the wheels when searching.
Pretty sure this one will need new rear tires and wheels for any semi-serious work.
/ b7200 #5
It probably has R4 (Industrial) tires and rims,R1's are AG type and you can't mix.Just get the size off the tire.You must keep the diameter the same or it will effect your 4WD.
/ b7200 #6
Go to Kubota Dealer but to sales not parts and ask them for tires and wheels thru Kubota whole goods.
(5) ROLL OF 9'X150' HOUSE WRAP (A62131)
(5) ROLL OF...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A61568)
2000 Thomas Built...
2012 John Deere 1790 Planter (A63109)
2012 John Deere...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
excavator trenching bucket- one bucket per lot (A63118)
excavator...
2015 Caterpillar 303.5E2 Mini Excavator (A61567)
2015 Caterpillar...
