B7200 clutch boot replacement
/ B7200 clutch boot replacement #1
pjferrante
Kubota B7200DT
Hello Folks,
I have a Kubota B7200 that needs a replacement clutch rubber boot put on to keep water, grim and dirt away. It is pretty ripped up and sometimes fluid leaks up out of it when I am running the tractor.
I can see that it is attached with a clamp that is pretty easy to take off and put back on. However, I don't have a parts manual and I don't want to break anything so was wondering if someone with a parts manual might be able to tell me if the clutch knob screws off so I can slide the new boot on or do I have to take it further apart to put the new boot on. I could easily just get a wrench and try to see if it will loosen but hate to break anything when I can just ask.
Thanks in advance.
Pete
/ B7200 clutch boot replacement #2
Mine just popped off with pressure. Never really wanted to stay on afterwards though, probably could have used a dolp of epoxy.
Freightliner Tender Truck - Adams Tender (A63118)
Freightliner...
Location Info Please
2005 Kobelco 135SR Hydraulic Excavator (A61567)
2005 Kobelco 135SR...
RoadTec RP190 (A63118)
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
2021 CATERPILLAR 299D3 SKID STEER (A62129)
2021 CATERPILLAR...
