You have regular agricultural type tires on your
B7100. These tires have the most aggressive type lugged tread used on compact tractors, provide the best overall traction, and are designated R1 type tires.
Turf type tires are generally wider and on slightly larger (wider) rims, with a very mild tread pattern that won't tear up the yard. These tires usually provide the lowest degree of overall traction, and are designated R3 type tires. My
B7100HST has turf tires with a front tire size of 20.5 x 8.00-10 and a rear tire size of 29 x 12.50-15. Same model as your machine, just different tire/wheel sizes.
Industrial tires, or the R4 type tires you've probably heard about, are kind of a cross between the R1 and R3. They have lugs like the R1, but are much less aggressive than the agricultural type tire, are a bit wider with a flatter footprint, and will provide better overall traction than turf tires, but less than ag types. These are pretty common tires on a lot of tractor/loader/backhoe machines.
Anyway, since you have the agricultural type tires, if/when you replace tires you'll probably want to stay with the same type tire. Otherwise, I think you might have to change rims, and that could get pretty pricey.
If you're new to compact tractor ownership, you might want to consider investing in Muhammed's book that's available here on Tractorbynet. Word has it this handy little reference guide provides a lot of educational material on compacts and it just might help you do a good job of taking care of that new
B7100 and of even greater importance, operating it safely.
Bob Pence
