B7100HST Mower engagement problem
/ B7100HST Mower engagement problem #1
Michialb7
Grove City, Ohio
B7100HST
I am looking at a 1983 B7100HST-1300 hours with a belly mower. The owner said he has problems when trying to engage the mower. it makes a grinding gear noise. I talked to a Kubota service mechanic but he said he was not for sure what the problem was until he seen the tractor. He also said it could cost up to $600 for labor and possibly$400 for parts if they had to repair something inside the case.
The seller is asking $4000 for the tractor as is. Is this a descent price considering it needs repaired?
/ B7100HST Mower engagement problem #2
Welcome to TractorByNet!
We moved your thread to the Kubota Owning & Operating forum. :)
/ B7100HST Mower engagement problem #3
Even though it is a HST, the clutch must be depressed all the way in when engaging the mid pto which drives the mower. If grinding gear clashing sounds still occur with the clutch fully depressed, I would suspect the clutch requires an adjustment or being a 30 year old unit, it may need replacement....I'd offer $3500 and hope its only adjustment.
I called them again and they said they tried adjusting the clutch so it sounds like it will need replaced. They said they would take 3500. I plan on looking at it and take 3200 in cash, what do you think knowing it will need a new clutch?
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
John Deere XUV855M (A64127)
John Deere XUV855M...
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
