Traction B7100HST creeping
/ B7100HST creeping #1
radioalbany
Rogue River, OR
Kubota B7100HST
Hi, all!
Just bought my first tractor for my hobby farm in Oregon, and haven't even taken delivery yet.
My on-scene expert tells me that the Kubota B7100HST creeps forward very, very slowly when
neither the forward nor reverse pedal is pushed.
I'm not terribly concerned about this, and I recall reading that many HST tractors tend to do it.
On the other hand, do any owners know if this is something a simple adjustment might cure?
Many thanks for the help!:confused:
Andrew Ellis
radioalbany
Rogue River, OR
/ B7100HST creeping #2
Many years ago my Ford 1210 crept forward very slowly. Linkage adjustment fixed it.
/ B7100HST creeping #3
Welcome to TBN. Creeping is not normal or acceptable. Most times its a simple fix. It could be because the hydro pedal is not self-returning to the neutral position. A shot of lubricant or grease to the hydro pedal pivot would be my first suggestion. A new return spring the second.
/ B7100HST creeping #4
Underneath there will be a V shaped plate with a roller that centres at the neutral position. Make sure the roller is on the V correctly, lubricated and operating properly. Some adjust can be done here.
For really fine adjustment you will find a plug on the right side of the transmission. Remove the plug and you will find an eccentric adjustment bolt/screw for small corrections. :)
Taking off the top metal cover housing the filter will give better access to the main adjustment arm. Sometimes the bolt holding it on the shaft loosens up.:)
Send me an email and I can forward some manuals for tractor, loader, mower.
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
EZ Trail 3400 (A63118)
2024 SILVERBACK SB50WCH 50FT TRI/A GOOSENECK CAR HAULER TRAILER (A59910)
2024 SILVERBACK...
2016 FORD F-250 (A63569)
2016 FORD F-250...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
iDrive TDS-2010H...
