B7100DT - Steering Box Lubricant?
   / B7100DT - Steering Box Lubricant? #1
Phoenix, Arizona
Kubota B7100
In all my Kubota manuals, I can't seem to find anything about the proper lubricant to put in the steering box. Is it 80wt gear oil like most other things or ??? The previous owner neglected the steering box and it had 6"-8" of freeplay and the box was full of water and oil!:mad:
I've adjusted the freeplay down to about 3/4", but I need to know what lubricant to put back in the box. Thanks! :)
   / B7100DT - Steering Box Lubricant? #2
HI there,
My B Series Kubota maintenance chart says that the steering oil grade is SAE10 to 20, although here in the uk the kubota dealer says to use the equivalent of Super UDT in all of the tractor, engine, gearbox, axles etc and as we dont have super UDT in the uk to use BP super Agri MP, which is what I do in my B7100. The cahrt syas that it takes 0.2 litres to fill it.
Hope this helps
Mat
   / B7100DT - Steering Box Lubricant? #3
Sorry must be the time I meant to say that the chart says it takes o.2l to fill it!
Mat
   / B7100DT - Steering Box Lubricant? #4
My B7100 service manual says : 0.2 L SAE 80 gear lube
Thanks! That's what I assumed, but I wanted to be sure.:D
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
2005 Ford F-250 4x4 Ext. Cab Pickup Truck (A48081)
2005 Ford F-250...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
