B7100DT - Steering Box Lubricant?
   / B7100DT - Steering Box Lubricant? #1
Phoenix, Arizona
Kubota B7100
In all my Kubota manuals, I can't seem to find anything about the proper lubricant to put in the steering box. Is it 80wt gear oil like most other things or ??? The previous owner neglected the steering box and it had 6"-8" of freeplay and the box was full of water and oil!:mad:
I've adjusted the freeplay down to about 3/4", but I need to know what lubricant to put back in the box. Thanks! :)
   / B7100DT - Steering Box Lubricant? #2
HI there,
My B Series Kubota maintenance chart says that the steering oil grade is SAE10 to 20, although here in the uk the kubota dealer says to use the equivalent of Super UDT in all of the tractor, engine, gearbox, axles etc and as we dont have super UDT in the uk to use BP super Agri MP, which is what I do in my B7100. The cahrt syas that it takes 0.2 litres to fill it.
Hope this helps
Mat
   / B7100DT - Steering Box Lubricant? #3
Sorry must be the time I meant to say that the chart says it takes o.2l to fill it!
Mat
   / B7100DT - Steering Box Lubricant? #4
My B7100 service manual says : 0.2 L SAE 80 gear lube
Thanks! That's what I assumed, but I wanted to be sure.:D
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
Payment Terms (MUST READ) (A50775)
Payment Terms...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
