B7100 Wheel nut specs ?
/ B7100 Wheel nut specs ? #1
dennis52
Queensland Australia
Kioti DS4510HS , Kubota B7100
Just bought replacement hubs and tried to look up the wheel nut specs in my manuals; couldn't locate them in the owners manual or the workshop manual or the Technical manual!
I looked at the general settings for bolt diameter and type and have put the rear on 80 ft/lb and the front on 35 ft/ lb . Seems a bit low for front ? Anyone know?
/ B7100 Wheel nut specs ? #2
I can tell you for a B2710 the front torque is 57.2-66.5 ft-lb. Rear is 80-93. My fronts are M12 I think, grade 7 if that helps.
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A63569)
2012 SOUTHERN VAC...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
Wolverine Skid Steer Stump Grinder (A64047)
Wolverine Skid...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A63569)
2019 GALYEAN...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
