Oil & Fuel B7100, What kind of oil for steering box?
   / B7100, What kind of oil for steering box? #1
Randybee1
Hey guys, what kind of oil/grease do I put into my steering box on my B7100?
Thanks.. Randy B
   / B7100, What kind of oil for steering box? #2
I used gear oil, 90W.
When I topped mine up, the first thing I found out was that it leaked. Fortunately seals are not very expensive.
   / B7100, What kind of oil for steering box? #3
Thanks.. Randy B
Use SAE80 or SAE90 gear oil in the steering box and front axle gear / differential cases.
Thanks, I'm still waiting on a service manual. If I had to guess I would have said 80-90 weight oil. I haven't checked it yet but I'm guessing with a 22 year old tractor its probably low ( or empty)
Randy B
   / B7100, What kind of oil for steering box? #5
You might want to pop it open and inspect the thrust bearings... gets expensive when they fail and take the worm gear assembly with them. :rolleyes: The bearings are $6 each and you need two.. the work gear assembly is about $150.
Charles
   / B7100, What kind of oil for steering box? #6
Thanks Charles. I think I'd better check that.
   / B7100, What kind of oil for steering box? #7
I re-lubed my steering box today, perhaps should take this advice also. I see in the manual that somebody replaced these thrust bearing earlier; they'd circled the part on the exploded drawing anyways. Will check this soon. Thanks. Tim
   / B7100, What kind of oil for steering box? #8
Move your steering lock-to-lock and watch the steering wheel from the side (easy if you lift the front with the loader). If it moves up much/at all they may need to be replaced.
2021 Bronco 255K XD Welder Generator (A55973)
2021 Bronco 255K...
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
Ammco Brake Machine (A55758)
Ammco Brake...
48ft all aluminum feather light wedge trailer (A56435)
48ft all aluminum...
