Oil & Fuel B7100, What kind of oil for steering box?
   / B7100, What kind of oil for steering box? #1
Randybee1
Hey guys, what kind of oil/grease do I put into my steering box on my B7100?
Thanks.. Randy B
   / B7100, What kind of oil for steering box? #2
I used gear oil, 90W.
When I topped mine up, the first thing I found out was that it leaked. Fortunately seals are not very expensive.
   / B7100, What kind of oil for steering box? #3
Thanks.. Randy B
Use SAE80 or SAE90 gear oil in the steering box and front axle gear / differential cases.
Thanks, I'm still waiting on a service manual. If I had to guess I would have said 80-90 weight oil. I haven't checked it yet but I'm guessing with a 22 year old tractor its probably low ( or empty)
Randy B
   / B7100, What kind of oil for steering box? #5
You might want to pop it open and inspect the thrust bearings... gets expensive when they fail and take the worm gear assembly with them. :rolleyes: The bearings are $6 each and you need two.. the work gear assembly is about $150.
Charles
   / B7100, What kind of oil for steering box? #6
Thanks Charles. I think I'd better check that.
   / B7100, What kind of oil for steering box? #7
I re-lubed my steering box today, perhaps should take this advice also. I see in the manual that somebody replaced these thrust bearing earlier; they'd circled the part on the exploded drawing anyways. Will check this soon. Thanks. Tim
   / B7100, What kind of oil for steering box? #8
Move your steering lock-to-lock and watch the steering wheel from the side (easy if you lift the front with the loader). If it moves up much/at all they may need to be replaced.
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
8065 (A55852)
8065 (A55852)
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2006 CHEVROLET EXPRESS SERVICE VAN (A58017)
2006 CHEVROLET...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
