Oil & Fuel B7100, What kind of oil for steering box?
   / B7100, What kind of oil for steering box? #1
Randybee1
Hey guys, what kind of oil/grease do I put into my steering box on my B7100?
Thanks.. Randy B
   / B7100, What kind of oil for steering box? #2
I used gear oil, 90W.
When I topped mine up, the first thing I found out was that it leaked. Fortunately seals are not very expensive.
   / B7100, What kind of oil for steering box? #3
Thanks.. Randy B
Use SAE80 or SAE90 gear oil in the steering box and front axle gear / differential cases.
Thanks, I'm still waiting on a service manual. If I had to guess I would have said 80-90 weight oil. I haven't checked it yet but I'm guessing with a 22 year old tractor its probably low ( or empty)
Randy B
   / B7100, What kind of oil for steering box? #5
You might want to pop it open and inspect the thrust bearings... gets expensive when they fail and take the worm gear assembly with them. :rolleyes: The bearings are $6 each and you need two.. the work gear assembly is about $150.
Charles
   / B7100, What kind of oil for steering box? #6
Thanks Charles. I think I'd better check that.
   / B7100, What kind of oil for steering box? #7
I re-lubed my steering box today, perhaps should take this advice also. I see in the manual that somebody replaced these thrust bearing earlier; they'd circled the part on the exploded drawing anyways. Will check this soon. Thanks. Tim
   / B7100, What kind of oil for steering box? #8
Move your steering lock-to-lock and watch the steering wheel from the side (easy if you lift the front with the loader). If it moves up much/at all they may need to be replaced.
Killbros 260 Seed Conveyor (A52748)
Killbros 260 Seed...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52748)
John Deere 5090E...
Woods 3 PT Blade (A52349)
Woods 3 PT Blade...
24' Free Standing Panel with Swing Gate (A50515)
24' Free Standing...
3001 (A51691)
3001 (A51691)
Land Honor Skid Steer Blank Plate (A50514)
Land Honor Skid...
