B7100 TLB
/ B7100 TLB #1
F2036
Well today I had a weak moment and bought a 1978 B7100 TLB . It stared kind of hard, #2 fuel and the temps in the 20's . It has a little over 1300 hours on the meter, and needs a little TLC. Nothing serious, replace some cyl seals and maybe a hose here and there, steering is tight, tires are 50% or better.
What kind of hyd oil does it use, and a whole bunch of othere questions are going through my mind
Where is the best place to get maintance manual for this little critter ? Is there anything special I should watch out for on this model Kubota?
all ideas or suggestions will be appreciated.
/ B7100 TLB #2
When I had my 1995 B7100HST I used Kubota tranny and motor oil from Kubota.
Keep air filter clean.
Keep check on rear wheel nuts etc. tight.
Don't over tighten oil drain pan nut.
May want to change rad. cap if your year has thermostat.
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
UNUSED SDLANCH 20' X 30' ALL-STEEL CARPORT (A62131)
UNUSED SDLANCH 20'...
New/Unused ATS-T460 Mini Skid Steer (A61166)
New/Unused...
Root Rake Loader Attachment (A61567)
Root Rake Loader...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
