B7100 Specifications
/ B7100 Specifications #1
BWSwede
Washington
Yanmar
Hi all,
This site is a great resource. I am glad I found it.
I am looking at tractors to purchase and I have had no problem finding the specifications to the new tractors. I have had a problem finding specifications for the older tractors, specifically the B7100. Does anyone know where I can look to find this information?
Thanks in advance,
Blane
/ B7100 Specifications #2
Will this help? If it is not readable send a private message and I'll try and get a better copy.
Egon
Egon,
Thanks for posting. Iam interested in the 4wd version and I can make out everything except:
1. Overall width?
2. Tread/Rear, the narrowest number?
3. Minimum turning radius?
4. Rear PTO, 540 and ?
Thank you very much,
Blane
/ B7100 Specifications #4
If you haven't already... try the Kubota website and look at B series tractors. These is a link at the top of the page for "Prior Models" .... or something similar. You can also look at Tractor Tips for some basic info on the 7100. Choose the "Tractor serial numbers and specs" link on the left... then choose your make and model from there.
Hey DmansPadge thanks for the post.
I had already looked at those sites but they are pretty thin on info for this tractor.
Thanks again,
Blane
/ B7100 Specifications #6
1. Overall width? = 1120mm or 980mm
2. Tread/Rear, the narrowest number? = 660mm
3. Minimum turning radius? = 2.1 m
4. Rear PTO, 540 and ? = 850 rpm
Please note the widths will depend on the type of tire mounted.
Egon
/forums/images/graemlins/grin.gif
/ B7100 Specifications #7
What kind of oil is recommended for the gear box on a b7100?
/ B7100 Specifications #8
If you have a manual it will say 80w-90, but that's wrong. I think it was in the 80's I got a notice from Kubota to use UDT in the the trans.
