B7100 HST neutral finder problem
   / B7100 HST neutral finder problem #1
6mmbr
Indianapolis, IN
I have a '94 B7100HST that is new to me. It had a problem where it would not return to neutral. The opposite pedal had to be tapped to get it stop travel in that direction. Annoying to say the least, dangerous an understatement. examination from underneath identified the problem, which prompted taking it apart to fix and clean. It required rear separation to get to it. This uncovered a bad U-joint. One thing led to another and I've got it almost all apart to begin restoration and rebuild.
Here though is the original problem:
The "neutral holder" (part# 66204-43310) had loosened and slid outward on its shaft such that it no longer rode upon the bearing (08121-06000) on the "arm neutral holder" (66204-43343). Instead it rode upon the washer which actually cut a groove into the bottom of the neutral holder and wore down the arm shaft. This positioning did not allow it to go back to neutral on its own. See the pictures below for normal and abnormal.
normal:
abnormal:
Amazingly these parts are available and I have replacements on the way. Otherwise I would weld 'em up and grind to spec. In order to prevent this from happening again (in case the HST shaft is worn and responsible) I plan to substitute a fender washer for the OEM washer (04011-50100) so that it overlaps the neutral holder preventing it from slipping off in the future.
thanks
Of course I couldn't stop there, so now my B7100 looks like this:
I have some degreasing/sandblasting/painting to do.
   / B7100 HST neutral finder problem #3
Looks like fun! And simpler; my old Kubota was a '85 B8200 19hp. Just compared to 1985, it seems like tractors have got lot more complicated.
Like your avatar...
   / B7100 HST neutral finder problem #4
I had 95 B7100HST for 14 years also had the same problem.
Seem the orginal piece/pieces weren't as good as the replacement parts,also the thicker grease during winter cold will at time slow return or not at all to netural.
Thats one heck of project...you have my attendion.
   / B7100 HST neutral finder problem #6
Had the same problem with mine. There is a10mm nut that is (say difficult to access) that can work it's way loose.
Note: there is a fine adjustment On the right side that works on an eccentric washer type principle.:D
   / B7100 HST neutral finder problem #7
I was going to suggest the fender washer anyhow...but I see you did that! Nice job!:thumbsup:
   / B7100 HST neutral finder problem #8
I was removing my universal joint for the front wheel drive and saw a little access panel on the right side of the tractor. I pulled the two 12mm bolts and I found I could access the neutral holder eccentric washer. I was able to remove both items and found the spacer was missing, this is why my kubota will drift untill I tap the hst pedal to stop the creep.
I thought i was goinig to have to split the tractor for the repair, but I was able to get the parts out with out too much trouble. Now to Kubota and get a spacer for the hst and a universal joint, rubber boot, band clamps and bushing to finalize the repair on the front wheel drive.
Ken
   / B7100 HST neutral finder problem #9
You might also want to check the roller that sits in the v configured plate that also centers the HST. :)
   / B7100 HST neutral finder problem #10
So glad to find this thread. After lots of searching finally a detailed thread with pics that explains how the HST pedal centering works. I'm a new owner of the same tractor with the same problem, hopefully with the same cause. Will take a look at mine today and see if that peice is off track.
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2020 Barreto 20RTK 36in Stand-On Trencher (A49461)
2020 Barreto 20RTK...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
