B7100 HST input shaft stripped spline
   / B7100 HST input shaft stripped spline #21
hi guys, new to this forum.
[SIZE=3]rockyroadnz[/SIZE] your info was very helpful, i split my tractor yesterday as i have the same problem (b7100hst-e). getting the shaft out was easy however the local kubota dealer isnt much help trying to find replacement parts. the tractor i have was purchased new in 1993 and i am the second owner. the hst input shaft i have doesnt have a woodruff key for the charge pump as it does in your post, it runs on a spline. where abouts was yours marked type 2? my housing doesnt appear to have anything stamped on it and by the manual is a new type. the prop shaft is almost had it as well and needs replacing so has been removed. the ball coupling also needs replacing. i would rather replace for genuine parts however failing that i plan to buy a universal coupling from rs components, welding the splines up, key both shafts and coupling and case hardening. TIA
   / B7100 HST input shaft stripped spline #22
G'day, I have carried out the same input shaft replacement as member rockyroadnz has. The tractor was running without any issues before I replaced the input shaft on my B7100 HST, type II. Now the tractor has very little to no drive, forward and reverse. I'm getting 40 PSI before the charge pump but only getting 10 PSI after @ the port 3 test port. I have removed the charge pump the second time to confirm that the dots on the impeller and the one on the outside ring are facing outwards / visible. Measured the clearances, between the impeller tip and it's outer ring, between the impeller and the plate it runs up against and all measured OK. Removed scratch marks on the plate that the impeller runs up against. That the O rings has not fallen out. Check for air entering the system. Cleaned the strainers and fitted new hyd oil filter. I cannot get to the charge relief valve unless I split the tractor again. I did not check this on both occasions when I has split the tractor.
Questions: could it be possible that I have incorrectly assembled the charge pump, around the needle roller bearing, washer, seal area, that is restricting the oil flow into the charge pump?
Any advice and suggestion will be much appreciated before I split the tractor for the third time, removed the charge pump and replace with new one, that is if I can still purchase a replacement.
Hello ABBIY. my only thought is maybe you have missed/dropped the key that goes in the keyway to drive the charge pump. I referred to it in step 4 on my lengthy post on May 19, 2018
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
2014 Toro Z-Master 5000 Series 72in Zero-Turn Commercial Mower (A56857)
2014 Toro Z-Master...
Electric Sweeper W/Pressure Washer, Water Hose, & Mister (New/Unused) (A59225)
Electric Sweeper...
1994 GMC Topkick (A57148)
1994 GMC Topkick...
2010 Cadillac SRX SUV (A56859)
2010 Cadillac SRX...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
