B7100 HST 4x4 hst running backwards
   / B7100 HST 4x4 hst running backwards #1
snpmorgan
Pensacola, FL
2011 kubota B3300SU, 2007 Kubota U25-3, 2005 Kubota ZG-2048, 1992 Ford 1720, 1992 Ford 1120
Just bought an older b7100. I mash the forward pedal and tractor drives in reverse. I mash the reverse pedal and the tractor goes forward. Please help
Let me add that the tractor will barly move when it does move and there is a grinding noise coming from the hydraulic motor area
   / B7100 HST 4x4 hst running backwards #3
I don't really know but the reversal of the pedal direction is hopefully just a linkage problem rather than anything inside the tranny. Grinding noise sounds ominous but hydro's can sound pretty painful at the best of times. It could have a blocked screen and being starved of tranny oil. That would explain the lack of power too. The screen is part 014 in the pdf. Its essential you check and clean it before anything else.
Kubotabooks.com
  • Screen.pdf
  • Pedal.pdf
   / B7100 HST 4x4 hst running backwards #4
Is it possible that the engine is running backwards? Check the battery terminals and see if the negative and positive are reversed. I do not know if this is even possible on this engine.
2018 LAYMOR SM450-ST SWEEPER (A51242)
2018 LAYMOR...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
2016 CHEVROLET EXPRESS PASSENGER VAN (A51243)
2016 CHEVROLET...
