B7100 fragile steering boxes
/ B7100 fragile steering boxes #1
chrisinnh
I learned something else from my recent hydraulics adventures:
One of the tractor salvage places I talked to said:
"B7100? Sure I've got at least a dozen of those... Wait, you're not looking for a steering gear box, are you? 'Cause those are all sold already. Hydraulic pump? No problem. Just make sure you take care of your steering box."
Apparently the B7100 (and I assume 6100 and 5100) have a fragile steering box?
It's the first I've heard of it, but if the salvage yard has sold every gearbox, then I guess It must be true.
I freshened the oil in mine.
/chris
/ B7100 fragile steering boxes #2
Kubota has parts to rebuild the steering box.
Mines been rebuilt once. They take a beating if you do a lot of loader work.:D
Kubota also have new steering boxes.:D
/ B7100 fragile steering boxes #3
if i remember it is like 600 for the complete box and 300 for the main gear that braeks inside thats y i did below and love it
/ B7100 fragile steering boxes #4
On mine the thrust bearings went out and the junk from the top one fell into the little worm gear assembly. I replaced the bearings but the damage was done. Ended up costing me close to $170 for a new shaft assembly (with the block full of bearings that rides the shaft).
When I opened it up it looked like no one had ever changed the fluid. The thrust bearings were about $6 each and you need two. If your steering wheel sticks, pops, or 'moves up' when you turn it go get the bearings.
Charles
/ B7100 fragile steering boxes #5
When I got my B7100 I noticed that there was no oil in the steering box. I filled it, now it leaks, so I ordered seals.
/ B7100 fragile steering boxes #6
My 6100 had the steering assy replaced before I purchased it. Glad I didn't write the check for it.
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Skid Steer Rock Digger (A65640)
Skid Steer Rock...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
2009 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2009 GREAT DANE...
1999 International F-8100 Truck (A62613)
1999 International...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
