B7100 Block Heater
/ B7100 Block Heater #1
aeblank
Cadillac, MI
Kubota L3940
So my brother has a B7100, and he's trying to put in a block heater.
Dealer sold him one, but the adapter is too large for the freeze plug hole.
Current thought is to machine down the in-hand adapter to fit the hole.
Assuming a .001 to .0015 press fit, but does anyone know the dimensions of the *real* adapter? There is a taper on it.
Also, the depth that it'll go in to the block, appears to be too far. In machining, we can limit the depth the adapter can go in....
All dealers say "sorry, discontinued". Is there any other (non-custom) solution? Buy just the *correct* adapter?
Let me know your thoughts, and I'll pass it along.
Thanks!
/ B7100 Block Heater #2
Not sure about that heater but make sure that the heating element clears the block when it's fully inserted no matter what you do. You also might look at magnetic or hose heaters if the block heater doesn't work.
Sent from my iPhone using TractorByNet
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
John Deere 6125R (A60462)
John Deere 6125R...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
