b7100 3 pt hitch stop?
   / b7100 3 pt hitch stop? #1
catch2nd
So I am building a weight box for my 3pt hitch to counter act the snowblower.
My concern is that when the hitch is all the way down is seems like it spongy, not a solid stopping point, and that all the weight sitting on it like that could break something.
Is this normal, should I just chain is up?
Thanks
Dustin
   / b7100 3 pt hitch stop? #2
You may consider setting it up so the three point is raised to hold up the box. When parked lower it to the ground.:D
   / b7100 3 pt hitch stop? #3
I just have a small stack of 2x pieces that serve the purpose of holding the weight of the 3ph ballast when the tractor is parked in the garage. I don't know if it helps the tractor but it sure makes me feel better that I don't have the 400-600lbs hanging on the back for no reason.
yeah, my thoughts also
thanks for the ideas guys!
   / b7100 3 pt hitch stop? #5
What kind of snowblower do you run? I've got a B748 and don't have any weight issues.
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
More info coming soon! (A55787)
More info coming...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2016 Dodge Caravan Van (A55758)
2016 Dodge Caravan...
