b7100 3 pt hitch stop?
   / b7100 3 pt hitch stop? #1
catch2nd
So I am building a weight box for my 3pt hitch to counter act the snowblower.
My concern is that when the hitch is all the way down is seems like it spongy, not a solid stopping point, and that all the weight sitting on it like that could break something.
Is this normal, should I just chain is up?
Thanks
Dustin
   / b7100 3 pt hitch stop? #2
You may consider setting it up so the three point is raised to hold up the box. When parked lower it to the ground.:D
   / b7100 3 pt hitch stop? #3
I just have a small stack of 2x pieces that serve the purpose of holding the weight of the 3ph ballast when the tractor is parked in the garage. I don't know if it helps the tractor but it sure makes me feel better that I don't have the 400-600lbs hanging on the back for no reason.
yeah, my thoughts also
thanks for the ideas guys!
   / b7100 3 pt hitch stop? #5
What kind of snowblower do you run? I've got a B748 and don't have any weight issues.
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2018 Ford Fusion Sedan (A55758)
2018 Ford Fusion...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
2016 Ford F-750 14FT Utility Flatbed Truck (A52377)
2016 Ford F-750...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
